Hi.
I'm doing the last few tests in the testing-phase now so I can have the final certification in May.
(Here in Norway, a final certification is required after the testingphase is completed)
Two of the numbers required is max altitude at soloweight and max weight. (Where VVI is 100'/min)
I don't really care to climb up there and find out since I don't think I'll ever go that high.
Vans says the altitudes are FL 200 and FL 250 so I guess I could use those, but it'd be nice to know if any of you out there has found anything else?
I've a Extreem IO-360 with dual P-mags, fwd injection, M/T two-blade prop and an emptyweight of 1125 lbs.
Has anyone with a simliar configuration any numbers to share?
Thanks.
Thanks.
