N395V
There is another thread that I do not want to hijack "Why 2 comms for IFR" that had some comments that I think should be explored.
They were (sort of) you cant use the GPS function on a GR EFIS for an approach because it is nt an "approved device".
and (sort of) if alll you are left with is a hand held Garmin (GPS) to do an approach you are screwed" These aren't the exact quotes but close enough to make a point.
The first comment is true and I take no issue with it and the second comment is a point well taken, I would not want to have a portable GPS as my only option for an actual approach, but let me pose a question ( what if scenario)
You are flying to KMCB (McComb Mississippi) , approach plate seen below, from KPNS (Pensacola Florida) IFR in your RV8,\. You are equiped with a Wiley E Coyote super duper EFIS (experimental with super duper vision m, moving map, GPSS roll steer etc and a single comm and a Nav with DME and ILS (in one unit). Everything in the plane has been working fine and you didand logged a successful VOR check 12 days ago. It is winter and there is a stationary weather system over the Southeast.
You file direct KMCB with and alternate of KJAN( Jackson MS) forecast has KMCB 150' above minimums at arrival and KJAN at 1000' above minimums for your flight planned arrival time. You have legal IFR fuel reserves on board plus 30".
You make the flight and all is well. You are enjoying the view on top at 6000' and Houston center says " radar contact lost, cleared for the VOR/DME-A approach into McComb. You have the VOR DME tuned to the MCB Vortac the aural ID is correct, your Garmin 496 has the approach waypoints loaded.
You descend to 2000 feet. You check weather and it has seriously deteriorated. KMCB, KJAN, and every other airport within fuel range is now at mins for altitude and 2 miles visability. The ILS at KMCB is notamed out of service but the ILS at KJAN is functional.
You continue the approach into KMCB and can see the vortac directly below when the to/from indicator swings. You start your descent to 1500" needle centered and just before you get to egpew you notice your EFIS shows you about 1 mile North of course, DME and your EFIS agree on distance and the Garmin handheld just died. The Vor needle says you are where you should be.
Or as an alternative scenario your EFIS has no moving Map but the Garmin 496 disagrees with your VOR.
What would you do and why?
![vora.jpg](/proxy.php?image=http%3A%2F%2Fwww.bearcataviation.com%2Falbums%2Fairboss_personal_album%2Fvora.jpg&hash=8df5dc6ce42ed0a9bab609e1628aa421)
