Tools
Cleaveland Tools sells a good Kit too. It comes with the "Main Squeeze" which is a superior hand squeezer. Have done my whole plane with it, I never felt compelled to shell out the big bucks for a pneumatic. Ditto with the C-frame verses the DRT-2. But if you must have them, you can always have items omitted from the kit.
There are many items that are not in the kits that you will need.
The ones that come to mind are:
- Right-angle drill set
- Dremel tool with heavy duty cutting wheels, rotary cutter and sanding cylinder bits.
- Emery cloth
- Torque wrench (inch-pounds)
- Lots of #30 & #40 bits
- Lots of Sharpie fine tips
- Scotch-brite pads
- Tap set
- Boe-lube
- Snap-on screwdrivers (phillips head)
- Big compressor
- Shop Vac
- Metal files: Vixen, flat, triangular, needle
- Electric engraver
- Rolo-Flair 37 degree Flaring tool
- Good tube bending tool
- Tube cutting tool
Get a Band saw on day one. Throw away the blade it comes with and order a good metal-cutting blade from McMaster-Carr. This will save you tons of time.
Every single aluminum piece you put in the airplane needs to be edge-smoothed. If you can find the right tools to edge-smooth aluminum quickly but effectively, you will also save countless hours.
I have heard great things about the Tungsten bucking bar. If I were doing it over again, I'd get one of those from the start.
When you get to the electrical system, you will need a good wire stripper, terminal crimper, coax crimper, molex crimper, D-Sub crimper.
