As a first time builder, I have a dilemma and could sure use you input...I have the slowbuild 7 with empennage done and mounted on fuse. The fuse is done up through installing rudder pedals and brake lines. My wings are mostly one and temporarily mounted with bottom skins still off. My question is this: should I next rivet up the fwd fuselage, or install the engine mount and gear, or start the wiring harness (van's harness) or start on canopy or ??? Not sure what makes the most sense to tackle next? I'm anxious to get it off the sawhorse and onto gear! Any advice very much appreciated! (I have most items mounted to the firewall, but haven't riveted closed the recess cover) Thanks, Jim
