I am waiting on my slowbuild RV-8 wings.. what things should I consider? I’m already doing the Newton Aero caps (A30L Vans)
I’m thinking Garmin G3X, so is the Garmin autopilot the way to go? I’m not really sure what other options for an autopilot that I should consider. Should I order some Garmin (or whoever’s) servo brackets to install while building the wings?
What pitot tube is best? I want heated, is the Dynon one the hot setup? Again, I’m really sure what other options are out there, I like the look of the Piper blade though.. Does the Dynon play well with Garmin stuff? Does it have AOA capability?
Thinking about moving the pitot tube outboard one bay to prevent tie down rope clearance issues.. Do I purchase (or make) another wing inspection flange to cut into the next bay?
When building the tanks, should I install a return fitting just I case? I was planning on mechanical fuel Injection from Don at Airflow performance..I don’t know if I’ll ever need the return, but perhaps if I use the purge valve setup?
Any other things that I should consider while building the wings?
Thanks!
Thanks!
