What size bolts?
Rhino889
Mounting a James MK3 Air filter.
The 4 corner bolts...are these an AN-4?
It feels to tight to be? Mattituck is out of business or I'd call them :(
Correct, they are a course thread bolt. .25 if I remember correctly.
At least they are on my Precision Fuel Servo.
One more thing, I believe these typically use a stud not a bolt.
With the stud, you install it once, and the wear from periodic removal of the FAB is vastly reduced. The FAB is then held on by a nut.
This is pretty common practice in cast aluminum parts.
My Aerosport engine package ...
...included four drilled-head, 1/4-20, AN bolts for the filter box attachment. They of course get safety wired in place. Makes a neat installation.
