Wicked Stick
Ok, I've got 95% of the wiring done. (99% of the panel is wired and working and the entire fuselage is also wired and plumbed. I just finished removing the wings so I can now get back to business on riveting the 821 top skin, baggage door, canopy, windscreen, firewall forward stuff, etc.
My query is this:
Which order of the build should I do next ? top skin first ? hang the engine and run the cables ? Follow the plans or deviate from them ?
I've seen pictures of other builders hanging the engine before riveting on the 821 top skin. Is this structuraly ok to do ? I still have my fuselage standing on wooden 2X4 legs attached to the wing spar because I'd like to work on the canopy and windscreen without having to work from a step ladder.
I'm thinking of the following but need opinions from those that have gone before me.
1. Rivet the F821 skin to the fuselage and also do the baggage door.
2. Work on completing the canopy, windscreen
3. Mount the Grove gear, then worry about hanging the engine running the cables for mixture, prop, throttle etc.
Part of me says mount the engine, figure out where to drill the holes through the firewall for the 3 cables, then rivet the top skin on, but my concern is the weight of the engine added to the fuselage which is on the wooden legs instead of the main gear.
Opinions welcome.![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
My query is this:
Opinions welcome.
