I have an RV7A with an O-360 and new Hartzell C/S prop.
I dynamically balanced it to .06 IPS at 2300 rpm.
I still feel vibration through my heals and small of back, have 3/4 inch sound proof rubber mat on floor.
I have checked that the exhaust is mounted firm and no parts of engine are touching cowl.
My main concern is vibration at higher rpm, from 2200 to 2550 the vibration frequency and level changes as expected, however, from 2550 to 2700 there is quite a change in the type, level of vibration. I dont like using full rpm for takeoff and climb.
Should I dynamically balance at a higher rpm, say 2500, instead of the 2300 cruise rpm I used.
Currently from 2200 to 2400 it gives .06 IPS and at 2100 .09 IPS
Thoughts please
Peter
Thoughts please
Peter
