I am trying to understand all of the lycomming engines and figure out what IO-540 engines will work for the 10 without having to do much modification for the vans firewall forward kit.
thanks,
SNIP...
Many of the 540's are cerified as 235 HP or 250HP but the only difference if you look at the certified airplanes they were put on is that the RPM is derated to either 2300 or 2500 RPM to give them the lower HP. At 2700 RPM they all have 260 HP. SNIP...
thanks,
