What is this hole for? 09-05 step 1
On page 09-05 step 1 trhey have you use a step bit to drill out 2 holes. One is 3/8 and the other is a 5/8. I see that the 5/8 hole gets a bishing but I can't find in the manual where the 3/8 hole is used.
I ask bc I used a very dull step bit and it wandered and chewed up the spar. I have a new bit on order and I think I can drill it out but there is apossibility there will still be some marks that are outside the hole. If this is used for a bushing, like the 5/8 hole then I feel confident just smoothing it out ans building on. I looked in section 11, attaching the elevators to the HS but it seems after you roll the leading edge you wouldn't be able to get to that hole anymore.
Thanks for helping with this
Ron
