First step of trimming the canopy is to remove the molding flange. As someone that's never worked with Plexi before I have no clue what that means. The pic attached shows the side of the canopy. There a clear section about and inch wide, then 3 molded in lines, then more clear section that makes up the actual canopy. Do I cut below the molded lines, down the center of them, or above them?
