I think I understand it now.... It's like this:
The engine belt is spinning the alternator, the alternator is doing nothing, until you throw the master switch to alt, which then sends a small amount of power from the battery (through the breaker) to the alternator to magnetize its field, which allows the alternator to do its thing, powering devices and charging the battery. No?
Yes and no.
Initially it is as you say. After the alternator is producing power it switches to a self-exciting mode.
Sounds kinda kinky, yes?![]()
Self exciting means that once it is producing electrons, some of them are used to excite the field, the battery is no longer needed for that purpose. The field circuit goes through the Alt Field switch (and the VR) so that it can be controlled. Cars don't have that switch.Are you sure about the "self-exciting" bit? I think the whole purpose of the Master Switch and the Alt Field circuit breaker is to deenergize the alternator if there's an electrical fault. If the Master Switch / Alt Ckt Bkr can't do that, then why have them at all?
