Being new to Aerobatics there is a lot to learn about looking after the aircraft. One area I have been working on is the oil system in my RV7, and have recently fitted the half raven system with an Auccusump, as described in a very informative thread here on vansairforce. Very happy with the system so far. I was dumping around 2 quarts of oil an hour of aeors, after fitting the raven oil seperator that went to zero and no oil on the belly. (Still burn a little oil though) Yesterday I fitted the Auccusump, and tested it. I could go inverted for about 5sec before the oil pressure dropped to 25psi which I was told is the minimum safe oil pressure.
What I read in the manual for my IO360 M1B Lycoming engine is that at idle 25psi is minimum, and at cruise 55 to 95psi is the safe to operate oil pressure range.
I am doing aeros at 2500rpm and 24.5inchs. My engine is a tuned Lycon with high compression pistons. I find the oil pressure sits around 65psi for most of my flying, getting up to around 70 at my aerobatic power settings. This hasn't changed with the accusump though the pressure changes less as expected. Before I fitted the Auccusmp the pressure would drop very quickly when I went negative to 25psi in about 1.5sec, now I still get a quick drop to 45psi when I pull negative, then it slowly decrease to 25psi. Is this good for the engine?
Any advice would be appreciated. RV's are truly amazing aircraft and I am taking part with my RV in the Sportsman section of the National aerobatic competitions here in New Zealand next week.
RV7DES
RV7DES
