What Fitting Is This?
Status
Not open for further replies.
VF84Sluggo
Ok, I’ve guessed wrong twice on two orders for a new one of these fittings. It threads into a UMA mechanical fuel gauge. Local FBO’s don’t have one.
Can anyone tell from these pics what this fitting number is?
I called. They only have steel fittings.
I might go by in person to see if they can at least ID the thing. Thought I’d try here, first.
1/8th NPT to either a -3AN or -4AN. Its hard to tell based on a wooden ruler, but I would lean towards the -3AN. The -3AN will have a thread diameter of 0.375" and the -4AN will have a thread diameter of 0.43 on the flanged side. The FBO won't have one, but your local automotive speed shop will.
I don't recommend or support any of the links, they're for information only. Please buy only aircraft grade hardware if your level of risk tolerance requires that.
https://www.amazon.com/Black-Aluminum-Degree-Elbow-Fitting/dp/B07SWZMM76
https://www.amazon.com/EVIL-ENERGY-Fitting-Adapter-Aluminum/dp/B09D3S4LHM/
Looks good...thx much
Fitting
The OP is showing a D fitting-aluminum AN2D, 3D and 4D are all 1/8 pipe thread. Tube outside diameter respectively is 1/8" 3/16" and 1/4 3D would be the most common for small instruments.
The AN-822 spec was updated to MS20822 a while back. For the -4 size, there is also a -4-4...which gives you a -4 tube end and a -4 pipe end.
You can download the spec at Everyspec.com
Free catalog,
For future reference on a lot of products, send for a free Aircraft Spruce catalog.:)
I had the same problem with AN fittings till I found a reference chart in the fitting section of their catalog with actual size drawings of all the AN fittings and it eliminates guessing. :confused: Helped me anyway. :) After a while figuring their size becomes second nature. ;)
Well I'll be...:eek:
Didn't even know that was in the catalog. I've got one of them in a drawer at my hangar.
Thx much!
Status
