Looking for ideas: I have an Aerosport O-360 on my -7A. I'm pretty convinced the EGTs on 1 & 2 are 'different' than they were say six months ago. Hard to quantify, but I often see them running about 100 deg hotter than 3 & 4, and I don't THINK they used to do that. So today I did an in-flight mag check and saw this:
Cruising along with everything looking as stable and even as I could get it, 24 squared, EGTs hovering 'pretty' even around 1350 deg, ROP.
- Switch from Both to Right (Lightspeed): No change, in anything. Rock solid. (actually very impressive).
- Switch from Both to Left (Mag): EGTs on 1 & 2 rise immediately by over 100 deg, within about 3 seconds. EGTs on 3 & 4 stay fixed. Engine sounds and runs totally fine - just the EGTs on those two cylinders shoots up fast. They stabilize around 125 deg hotter than 3 & 4. Everything cools to normal when I switch back to Lightspeed or Both.
Any ideas what that means? If all four EGTs went up I would think nothing of it, but it is very clearly just affecting 1 & 2. Only about 120 hours on the engine, always run ROP.
Thanks -
Matt
Thanks -
Matt
