What compression ratio . . .
rv620mr
Member
. . . is produced when using a piston with a part number of "10437"? I see no other markings on this piston. It was removed from a Lycoming, O-360 (parallel valve) cylinder. Please assume "standard" length connecting rods and crank shaft throws! :D
piston
The current Lyc part number is 75089 for 8,5 to 1. nearly all parallel valve 360's use this piston. There are a few that are derated to 7.2 to 1, rated at 168 horsepower and approved for 80 octane. I find no reference for the pn you posted.
