Hi.
I'm in the middle of the testprogram for my RV-7 with an Extreem IO-360 with a 2-blade M/T C/S prop from Eagle Engines.
Emptyweight 1125 lbs.
I'm about to find the following data:
Max rate and max angle of climb speeds with correspondng VVI-readings(just after t/o)
Max range and max time decend speeds (after an engine failure)
Altiude lost in a 180* turn just after t/o (after an engine failure)
Max altitude at middle and max weights. (when VVI is down to 100'/minute)
Can anyone give me their data for these things? It'd be nice to have someone else's data to compare with my own.
