What are the pictured (circled) holes for? RV8 -1 kit. These are pre-punched.
scard Well Known Member Advertiser Aug 8, 2010 #1 What are the pictured (circled) holes for? RV8 -1 kit. These are pre-punched.
scsmith Well Known Member Aug 8, 2010 #2 rear seat throttle kit? I think the plate that holds the pivot for the rear seat throttle mounts to that rail.
T Transporter Well Known Member Friend Aug 8, 2010 #3 Holes On the left side, these are for the rear throttle mount as described above. On the right side, there is no kit/plan I'm aware of...but you may want to use them to mount a storage area panel. Mike
