dbuds2
Let me thank you in advance for your replies, I love this site and all you builder with experience.
I have the newer match drilled RV8 fuselage kit and have been planning the wiring routing. Can someone help me with what some of these holes are:
#3 is two holes with nut plates on the firewall angle
#4 is also two holes with nut plates on the firewall angle just above the throttle/mixture/prop holes
#5 is a small, looks like a tooling hole just right of cable holes.
#6 is about a 1/2" hole down low, maybe for 2AWG battery cable (rear Batt), and
there are 2 small holes left and right of main heater box hole, assume for mounting the heater box.
I'm planning to drill:
#1 for mags and alt
#2 use as is for starter contactor and could also fit 2awg battery cable.
![img35001nl9.jpg](/proxy.php?image=http%3A%2F%2Fimg3.imageshack.us%2Fimg3%2F1930%2Fimg35001nl9.jpg&hash=67db73cac47e5818ee57818bdc008722)
#1 for mags and alt
