jeffw@sc47
Like finding Waldo >
These two aluminum strips, each 29 1/4? long, 5/8? wide, 0.018? thick; may have originally come attached to each other and had to separate. They are now primed and the part numbers removed. There are 15, #27 holes equal spaced 2? O/C and about 1/16" off center down the strip's length. The holes align with the forward 15 holes of the 16 holes each side of canopy frame part C-01419-L&-R. They align perfectly with the zone 2 screw tighten sequence called out > RV14 Finish Kit, pg 38-27 figure 4. I have scoured instructions and cannot locate or identify. They would fit perfectly in the canopy frame there but no instruction that I can find to put them there.
I have also looked through the Fuselage manual, as well as the packing lists for a description that would match, NO FINDY.
The clouded highlight identifies the holes that align perfectly between the C-01419-L part and these strips.
EDIT 11:30am > I think I just found them >> Page 38-22, Steps 7. and 8. (Figure 3.); 'USE C-01423 IF REQUIRED". Shims if canopy thickness is less than needed.
