FORANE
It is tire change time.
I have searched and seen some methods of jacking such as on the tie downs, and floor jack to gear.
What is easy with minimal equipment such as when you get a flat away from home?
In the Lancair, I get under the wing on hands and knees and lift the wing with my back long enough to slide a wood block under the brake disc. No jack needed which is nice when away from home / help. Can this be done with an RV?
What method do you prefer to jack an "A" model?
Can one safely jack under the step?
