What are my options with A Dynon DEK 180
DennisRhodes
Presently have a D 180 installed in my RV9 . I would like to install another screen device to be able to direct the engine monitoring screen on to and still have the ability to use the 1/3 and 2/3 screen set up as presently on the 180 for EFIS AND HSI . I like the security of having the fuel levels, volts, oil Press and Temp visible. Is there a Dynon product or other that will communicate with the D 180 to allow me to do that short of another D180 or another complete separate device with sensors. I would prefer the screen size of the second to be smaller than the 7 inch. ??
You can add a D10A and network it with the D180 and do what you want. This will also give you a redundant EFIS.
It could look like this:
You can share engine data from the D180 to display a screen similar to this:
We don't make any "standalone" screens that are designed to only receive info from another screen.
You cheapest option to get another display is to actually sell the D180, and then buy a D100 and an EMS-D10, which gives you one 7" screen and one 4" screen. This setup has no redundancy, but does have a lot of glass area. The D180 is $3,400 and the D100+D10 is $4,100. The wiring is the same for the EMS-D10 as it is for the D180 so there would be almost no re-work needed on the wiring side.
If you want to keep the D180, then an EFIS-D10A is your cheapest option. This is $2,200. This will give you the ability to put any data on any screen, and will also give you a full EFIS backup as brantel mentioned.
I like that" best 'option as mentioned. I need to start looking for a EFIS D10A and believe I would be able to use the com connection wires supplied in the D180 harness from Stein for this interface to the second . Thanks for the quick response on the thread. / DRR
