Nomex Maximus
OK, this occurred to me the other day.
I have a dislike of having to reach out for most anything on the control panel. I think everything should be controlled from a new style of input device located at the pilots right or left hand when it rests on an armrest. The device is configurable in realtime according to the commands of a flight computer. But that's not what this post is about.
What occurred to me is the idea of the pilot wearing something like a virtual reality vision device. He can look through it and see normally, but it also projects flight information on a combiner in front of his eyes. Unlike a helmet mounted display which has all sorts of complicated mechanisms to track the motion of the head in relation to the outside environment, this device simply displays data directly in front of the pilot regardless of where the pilot is looking.
What it can be used for is for displaying lists of things to choose from - like radio controls, transponder codes, most anything you presently have to choose from when using a Garmin 4xx/5xx type of system. It is not intended to display airspeed/altitude/pitch/roll stuff, just the navigation and engine management stuff perhaps. But what would set this apart from current information displays is that the pilot has a virtual reality glove on one hand that allows him to point to items being displayed in front of him and select them by pointing to them. The great advantage is that you have a much larger virtual control panel (you aren't limited by physical panel space) to work with, and it is at exactly the right "distance" from where your hand and arm want to be - you aren't reaching for anything. And, since you head and arm bounce the same way in turbulence this approach is somewhat immune to turbulence.
For example, the flight computer would display a set of buttons doing something similar to the Garmin unit front panel buttons. You would press a button by pointing to it with your hand with the index finger extended and "touch" it. You would activate it by retracting your index finger, closing your fist and touching your thumb to your fist like you were pressing a thumb switch.
If you don't want to see the virtual display, then simply point to the button that says "standby" and the display will blank except for the button in the corner that says "resume".
Comments?
Comments?
