MartySantic
Page 31-07, Step 7.
Looking at the MAIN DB-25 pin connector on the WH-RV12-OPTIONAL harness. There is a white-black wire and a orange wire with female pins attached that are NOT inserted in the DB-25 connector. The wires are just hanging. Jim Cone saw the same.
Should these be left out of the DB-25. If NOT, in what pin locations should the two wires be inserted.
Traced the wires and they are a part of the future autopilot servo harness. There is an orange and a white black wire in this 7 wire AUTOPILOT SERVO harness. Page 31-09, Step 8. Checked with a DVM and there is continuity.
The same wires continue to the tail.
So they most likely SHOULD be inserted into a location on the MAIN DB-25.
