wirejock
This applies to several models.
The weldments like the rudder pedals and the flap weldment have bearing surfaces against the plastic mount. Delrin I think. Some are black, some are white. Is there a difference? My question is should they be installed dry or is there a lubricant appropriate to this application? I don't want anything attracting debris and causing problems.
Edit...
I didn't consider the steel might need something to prevent rust. Any thoughts apprectiated.
Edit...
