Good afternoon everyone,
The Garmin team has been monitoring this and wanted to provide some feedback for some information on what may be an issue. The change in side tone volume level observed is an indication that the aircrafts antenna system has a slightly different and higher VSWR at the band edge frequencies as opposed to the mid band range where most if not all COMM antennas have their best match.
In measurements that we've made on several different manufacturers antennas the band edges VSWR has always been higher than the middle frequency range and some installations are worse than others but they are typically of no concern with the transceiver that the user has.
Again, there is no concern with either the GTN6XX, 7XX comm. Radios or with the GTR/GNC series transceivers as we designed all of these transmitters to operate into an open and a short circuit without any damage.
A 2.5 :1 antenna VSWR, of which one could experience at the band edges in some installations, is also the point where the side tone would start to change and be noticeable and this VSWR is also within aviation antenna manufacturers standard operating range.
The antenna manufacturers err on the high side of their VSWR ratings to account for issues such as bent whip antennas close to the aircraft bodies, antennas close to an ELT or another style antenna or aircraft structure and also for antennas with smaller than normal ground planes.
Let me know if there is any questions,.
Best Regards,
