I've been troubleshooting a transmitting problem for a while now and still haven't come up with an answer. I have a Terra radio that has good reception and transmits well on the ground (loud and clear) but when in the air everybody says it sounds bad, like 2/5 or 3/5 or just "unreadable". I've tried different headsets and all the usual troubleshooting steps and today even plugged in my handheld to the antenna coax and had the same results. I powered the handheld from the plane and then by its battery and people said it sounded a little better with the battery.
So, transmits and receives well on the ground but only receives well in the air. It seems to be pointing to the antenna but why only in the air?
Any input from the radio gurus would be greatly appreciated.
