liuk
Active Member
Hello all,
I recently started having a weird noise on my 2nd COMM, which is a Icom A210. The radio starts quite, but after receiving some radio transmission (Rx), it will continue giving out static noise after the radio transmission is completed. The noise does not seem to be affected by squelch setting. The only things I can do to stop the noise are the following:
- Turn the radio off and on again (switching the intercom channel does not help)
- Switch to the backup frequency and then switch back, i.e. quickly press the switch button twice
- Make some transmission on the radio. It works even if I just press the PTT for half a second.
After the noise is gone, it remains silent until next time it receives some legitimate radio transmission, then everything goes all over again.
I searched the forum but couldn't find anyone with similar experience. Could you give me some suggestions? Thanks a lot.
