Preface:
After reviewing "as built" weight & balance info on Dan C.'s website, I am trying to do some advance planning.
It does not appear to be possible to build a -7 at the forward end of the CG envelope. The most forward empty CG listed is 77.65. For a 160 lb. pilot and 20 gallons, I calculated the CG as 80.16, which is aft of the forward aerobatic CG.
My problem is the opposite. At 6'4" and 240Lbs. I won't have any trouble w/ W&B falling in the aero CG envelope solo. However, since the pilot and passenger sit 20" aft of the empty CG, my concern is X-C flying with baggage. At the end of a trip with my average weight spouse, with minimum fuel and 100Lbs. baggage, it seems that we will be right at the aft CG limit. Were I to travel with a heavier passenger (e.g., my 6'8" 240 lb. son) we would absolutely be behind the aft CG limit.
Question:
The other day there was a thread about consideration of using a "long" Vans cowl and 320 engine mount with the 360 engine. This would appear to have the potential of addressing this issue. Rough calculations suggest that moving the engine/propeller combination 2" forward would move the empty aircraft CG forward about 2/3". Could the individual who made this suggestion please comment on both the degree of difficulty and the plausibility of doing this. Is it reasonable that the engine mount could handle the extra torque and weight of the 180 hp engine? I gather from another thread that there are not any SJ cowls that would accommodate this suggestion?
Larry Tompkins
currently constructing wings
Question:
Larry Tompkins
