Mark33
Hi everyone! I'm building an RV-7 (tail dragger) and have a question about weight and balance. Does a 7 tend to be nose or tail heavy? I'm building mine with a parallel valve IO 360 and a Whirl Wind RV 200 constant speed prop. I have two Odyssey 680 batteries on the firewall but I'm concerned about weight and balance. I'm also using the "oil-o-matic" pre oiler which is also mounted on the firewall along with the oil cooler itself. I've heard that the 7's tend to be tail heavy so I'm hopping that the extra wight of the items mentioned above will help balance things out a little.....but not to much! With my current setup, the only thing that I may be able to change is the location of the battery (s) in the event it turns out to be nose heavy. Any expert advice?
