Lan Vinh Do
Hi
I am about to make a trip with 4 adult and luggage baggage.
I have a mt prop and a 02 tank in the tail so my cg is probably more aft that others and as i burn fuel, my cg go farther back.
When i calculate my w&b i am ok on take off but if i land with only 10 gal, i will be 0.2 inch pass the aft limit.
My queation is : is the 114.58arm for pilot and copilot is calculated with the pilot seat completely at the rear position. I am only 5feet 7 and i always put my seat the more foward i can. So of i put the pilot front seat at 112.58, i am ok.
if not, anything bad to land with a cg 0.2 inch aft of the rear limit?
