and added a few mods. You'll have to add the actual position measurements for the gear. Note the calculation of the nose wheel weight I added. For the 7A, Vans specifies a maximum of 375 lbs. Probably not an issue in the 9A, but you should check...
OOps - no email address in your profile. email me from my profile
I have a set of scales (racing) that you can borrow if needed. They will probably be in the next hanger over from you this Saturday weighing the Ercoupe. Let me know if you need them. I also have a spread sheet that I have used on mine.
COULD SOME OF YOU WHO HAVE RECENTLY DONE WT AND BALANCE ON YOUR 9A EMAIL ME THE OUTCOME. I WOULD LIKE TO COMPARE NUMBERS TO THE W&B I DID ON MY 9A THIS WEEK. THANKS, JOE [email protected]
