Good Morning! Looking for advice ..
I had a slight fuel smell in the cockpit last few times I opened it up ... tracked it down to a very slightly weeping fuel sender bolt.
My goal is to fix it without taking the entire fuel sender out.
My plan is to get the fuel below the sender, remove the weeping bolt, clean everything with alcohol, coat it with copious amounts of proseal, and re-install with fingers crossed.
Thoughts?
Thoughts?
