Mike-
on the 10, you have a bit more area to cover. For me it was a pretty short list... The BIG number uno is dont try to be an artist & skimp on the sealant!!!! I used 2.5 Quarts of PPG Desoto 890B2 ($$$$$). I used a proseal gun to lay down FAT beads on every joint & formed nice fillets with a brass spoon. No popsicle sticks used except for mixing. I also scuffed, layed down PPG PR-148 adhesion promoter, topcoated every cured joint / encapsulation with lab grade toluene thinned sealant... You'd be amazed what you find after you scuff your cured joints & encapsulations with a fine stainless steel brush!!!
http://www.yardstore.com/browse.cfm/4,5955.html
http://www.yardstore.com/browse.cfm/4,6419.html
Anywho-
I'll stop blabbing about my process. Here is the Key point I came up with
#1-Thanks to Walt, plate-nuts were pointed out as a big leak risk. domed /sealed plate-nuts cure that. I top coated those also
http://aircraftproducts.wicksaircra...08?&plpver=10&origin=keyword&by=prod&filter=0
#2-The rear baffle. If you search weeping rivets & look at the pictures folks have posted here, you'll quickly notice that most of the complaints about weeping rivet are located on the rear baffle joint. and Vans cautions you about build up here But I loaded it up, especially in the corners, wet riveted in the same session, cleaned up the eternal excess, encapsulated all the rivets, put waxed paped on spar & clecoed in place to cure.
#3 I didnt do this but dimple the skin & rear baffle rather than countersinking. The baffle dimples can be touched up with a debur bit for a better skin-dimple fit. This ensures perfect alignment. If you kind of paint the sealant on this joint with an acid brush AND lay down a bead dead center on the rivet line, plenty squeezes to form a nice consistant bead on the inside while still leaving room for the water drain line.
#4 for the capacitive sender plates, be sure the wire - terminals are sealed to the plate and wire insulation on both sides of the plate to ensure no fuel seeps into the wire & out the BNC connector.
#5 AN fittings use only a small amount of sealant to seal during assembly (not the threads) & then seal well with decent fillets on the inside after torqueing... Also Note that there are different torque values for AN fittings, bulkhead torque values & flared tube torque values. I posted those here a while back
#6 Take your time!!!
I spent about 130 hours on my tanks. If they leak any time down the road, I'll litteraly cry.
