Weak Comm Reception W/Increasing Altitude (GNS430)
Toobuilder
Hi all,
Ran into a new problem on the last cross country in the -8. The airplane is equipped with a GNS-430 and a SL-30, with dedicated antennas on the belly. On this flight I was using the 430 as my primary comm and as I climbed through 9.5k on my way to 11.5k, my reception of ATC grew increasingly scratchy until it was nearly unreadable. I dialed in the freq. on the SL-30 and switched radios on the audio panel and the problem disappeared... reception was clear as a bell. To compound the confusion, the 430 started working fine again once below about 9k. I don't know if the 430 was transmitting poorly at any time, but ATC did not have any complaints.
Anybody have any ideas?
Swap two antennas on the back of the units and see if the problem follows the antenna or the unit.. it'll help you narrow down what to look at next.
