WD 721 hardware call out
marvk
Member
I am installing my landing gear supports (7A) and on page 34A the hardware call out shows to use six AN4-12A bolts with washers and 365-428 nuts. This is to attach the WD-721 to the front of the main spare. Problem is if i use these bolts I have no threads sticking out of the nuts. It appears i need to use AN 4-14A bolts. the 1 1/4 bolts are to short. Am I missing something or is the hardware listed on drawing 34A incorrect? Thanks
Mine are the same way. My tech counselor tells me that after flying a bit, they'll need to be tightened up a bit. But it looks like I'll need the longer ones, too.
I used longer ones. Don't know if those bolts in the bag were for that purpose, but I haven't been at a loss for extra hardware so far in this build.
