ShookieRV7A
I am in the process of installing my gear legs and I am still scratching my head on this one. I have made the gear leg cutout in the F-772 skin and some of that cutout does go into the flange of the F-704 spar. All of this is on the left side so far.
However, there is still a sizeable gap between the lower portion of F-704 spar and WD-721, most notably where the NAS bolts will attach the wings to the fuselage. It appears from looking at rub marks on the WD-721 socket that I am still not close enough to the spar. There are rub marks right at the weld between the socket and the bracket.
Here is my question:
Just exactly how much material from the spar flange on F-704 is allowed to be removed?
I am really close to the double flush rivet now (probably 1/16" to 1/8").
