Wes Hays
Need some help!
Could someone measure the thickness of the WD-643 Roll Bar Brace plate that slips down into the top skin between the F7108A Center Rib and the F7108B Angle?
Dwg 24 says to put an AN960-6 washer on the aft most rivet hole on the F7108A to create a gap for the WD643. But IIRC, there was a shim on the -6A along the length of the angle to keep the angle and rib from being bent or twisted when it was riveted together. I must be missing it on the plans.
I think it was .040 or .063 but I just can't remember. (Old age I guess).
Thanks in advance for the help.
