dsvajda
Active Member
Some lessons are learned the hard way. When you buy someone's kit, you not only get to make your own goof-ups, you get to discover any the other builder may have made. In my case I just discovered a goof made over 10 years ago by one of the first two owners of the empennage kit.
While hanging the elevators I found that the hole through the WD-605R&L for the AN-4 bolt is about 1/16" too close to the tube so I can't get a nut to start:
[/URL][/IMG]
It's drilled per the plans at 13/16" from the center of the tube but I'm guessing it wasn't drilled in assembly with the bearing.
I could probably get an MS21042-L4 on, but would that be acceptable? I've also thought of fabricating back plates from .063" 4130 moly and rivetting it to the outer surface of the WD-605's then redrill.
Any good ideas on a solution, short of building new elevators?
Dave
RV-6 Finishing ( and possibly empennage)
![dsvajda](/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fs1211.photobucket.com%2Falbums%2Fcc433%2Fdsvajda%2F%3Faction%3Dview%26current%3DDSCN0793-1.jpg%5D%5BIMG%5Dhttp%3A%2F%2Fi1211.photobucket.com%2Falbums%2Fcc433%2Fdsvajda%2Fth_DSCN0793-1.jpg&hash=3f6b5b5a728ff3f27509c1f2319371e5)
Dave
