s10sakota
Hello all,
Regarding the WD-409 tail spring bracket: I have the forward holes match drilled to the F-711 bulkhead. What is the best way now to open the holes to final size?
Should I drill the WD-409 separate from the F-711, or put them together and drill through all at once.
Also regarding drilling, I've read about people using reamers to drill these holes. When I use drill bits, I get triangle shaped holes which of course, I don't want here. I am not familiar with drilling with reamers. I imagine I drill it slightly small (what size bit?) and then turn a reamer in the holes for final size?
Thanks for the replies!
