It should flatten a little with rivets, but be careful not to deviate from the plans and alternating the the rivet pattern. If you follow the directions, you will keep the trailing edge straight. That's by far more important than the "bumps".
If you search the archives on this site, you will see many posts about this challenge. It ends up being a smaller deal as you move onto other things in the build.
BTW...I would still look into the angle iron idea. About 1/8th of an inch thick X 1"X1"X8 feet long. Make a bucking bar with two sets of holes like the link shows in the previous post. Use the line of holes for every rivet spot to cleco during Proseal stage. Once dry, move to the trailing edge to the set of holes that is every other hole. This allows you to put a rivet in the other spots and use the bar for a bucking bar. Once those are driven you can move the assembly one space over and do the remaining rivets.
It keeps everything absolutely straight. On the 10, this needs to be done again on the wing control surfaces.
Make sense? Hope this helps.
