washer part number?
Bevan
What is the part number for the small diameter washers one would use with a rod end bearing that is smaller OD than the standard 960 type washer?
This would be used to use as a spacer for a rod end bearing that is small enough in OD to not interfere with the bearing's operation?
Bevan
Look on Van's order page for WASHER 5702-75-60.
It is called out on the wing attach & control system schematic page.
Thanks Bruce. Would like to add some to a Spruce order but that part number is not valid at spruce. Surely Spruce must carry them (possibly under another number)
Bevan
I believe that you will find it listed as NAS1149CO363R for the AN3 or 3/16" bolts at VAF advertiser Aircraft Spruce.
The AN960C washers have the same OD as the cad plated AN960 washer. I don't believe that's what the OP was looking for, and I think Vans is the only source (although you might find something in the aviation aisle of your local hardware store that would work equally well - just make sure it's stainless steel).
To the OP: If you only need one or two I could send them in an envelope.
