Ron Lee
From public sources we can use the FAA registry database to find that one S/N AC-3 aircraft is N424D.
The FAA registry listed owner is the same as news reports as one of the two killed in the crash. One such news report is here:
http://tinyurl.com/cjafonm
In that same report, a NTSB member called the plane an “RV6” yet the FAA registry has the model listed as “RV-6-CH.” These are not identical so at this point there is no obvious tie to the Vans RV6...prototype or otherwise.
In the N424D registration paperwork, in a letter dated January 8, 1996, the requester uses this nomenclature:
Make: RV-6
Type: Airplane
Model: Chard-6
Serial Number: AC-3
And it is stated: “This aircraft has not been previously registered anywhere.”
According to the Vans info on the RV6 series aircraft, that model was introduced in 1986:
http://www.vansaircraft.com/public/rv6.htm
I am not an aircraft designer so many things are beyond my grasp, but it appears patently impossible for an aircraft (N424D, AC-3) which was registered for the first time in 1996, to be the prototype for a model that was introduced about a decade earlier.
So where does the Chard-6 and RV-6-CH info originate. The first apparent use of “Chard-6” is the registration letter of January 8, 1996.
On a Form AC 8050-1, dated 30 Jan 96, in the “Aircraft Manufacturer and Model” block is listed two people’s names along with “RV-6 Chard-6”
That is not the same as the current FAA registry “RV-6-CH”
In the Affadavit of Ownership for Amateur-Built Aircraft, dated 31 January 1996, the Make/Model is listed as RV-6/Chard-6. So the model is a Chard-6, not an RV6.
When you look at the Airworthiness files, there is a letter dated April 2, 1996 where the make/model was noted to be incorrect and was changed from RV-6/Chard-6 to McDaniel/RV-6-CH.
So whether it is a Chard-6 or a RV-6-CH, it is in my opinion not a Vans RV-6 and not a prototype for the plan that I fly now.
This eliminates any concern that I have....as a RV-6A owner...that the crash earlier this week has any relevance to the structural integrity of my aircraft.
Make: RV-6
Type: Airplane
Model: Chard-6
Serial Number: AC-3
