W&B
RV8R999
Just completed my W&B
Right 530#
Left 526#
T/W 67#
Empty 1123#
Empty CG 79.64"
How does this compare with others?
Thx,
Ken
Mine is 1137 lb, at 79.38". IO-360-A1A (angle valve) and Whirl Wind 200RV, battery in the back.
1125 and 77.6
IO-360 parallel valve
battery in back
CSP
Not sure why my John Ciolino and my cgs are that far forward compared to the others.
RV-8, IO-360A1B6, Hartzell BA (F7497 blades), battery in back.
RW: 548 68.97
LW: 567 68.97
TW 50 251.5
Total: 1165 @ 76.8
The plane was mostly unpainted as weighed, but the cowling, canopy skirt, windscreen fairing, and front top skin are all well prepped, filled and painted. I also have a well equipped instrument panel:
Skylor
RV-8
Flying, 40.2 hours
"PERFECT" PANEL
Skylor ---- that is about as perfect (from MY perspective) a panel as I have seen in an RV-8. Functional with adequate backup.
Ron Simonton
After Painting; 200 HP angle valve and Hartzell CS prop
Right Wheel 540 68.76 37130.40
Left Wheel 545 68.76 37474.20
Tail Wheel 57 251.06 14310.42
Totals: 1142 88915.02
Empty Aircraft Data
Empty Weight: 1142 lbs
Empty Moment: 88915.02 in-lbs
Empty C of G 77.86 inches
C-G Range (Per Designers Specifications):
Forward 78.70 inches
Rear 86.82 inches
Rear Acro 85.30 inches
Max Gross Weight (Aircraft Manufacturer): 1980 lbs
Empty weight 1144
CG 78.9
  • IO-360-A1A
  • Hartzell Prop (not b/a)
  • Inverted oil system
Everything I could put in the back I did:
-Strobe power supply
-Smoke oil tank and pump,filter,metering valve
-ELT
-Battery
