W&B in ForeFlight?
FlyingBliss
Member
I'm in the process of setting up the W&B profile for my RV-10 in ForeFlight but I can't find the forward & aft CG weight limits in my aircraft W&B document that are required by ForeFlight to complete the W&B profile setup. What should I enter for these limits?
Use your empty weight and gross weight at both stations. Like this:
Btw mines an RV6A.
This is what I have for mine. Cannot say for sure if yours are the same or should be different.
It’s the “Design CG Range” in the W&B for the locations and then your empty and gross weight at each
