Error Analysis
It has always bothered me how some pilots use an average arm for the pilot, copilot, and baggage, and then run the cg right to the edge.
(My spread sheet lets me put in the actual arms for front seats, bags).
I did a little error analysis for my plane, in typical aft and forward loadings. Here are the results.
I arbitrarily looked at what it would take to move the cg by 0.11"
Aft case (front seats 340 lb, pass seats 250 lb, 150 lb bags, full gas)
When weighed plane, main gear off by 3%
When weighed plane, nose gear off by 1.2%
(these two tend to cancel, so if it was the scale that was off it would need to be off by 2%)
When weighed plane, main gear arm off by 0.25", OR nose arm off by 0.75"
Pilot and copilot position off from average by 1"
Pilot and copilot weight off by 200 lbs (!)
Passenger weight off by 9 lbs (!!) (Do your passengers tell the truth?)
Bag weight off by 5 lbs (Do you weigh your bags?)
Bag location off from average by 2"
Gas off by 7 gal (this is why you need to check take off and landing cg).
Forward case (one 170 lb pilot, 25 lb bag, full gas)
When weighed plane, main gear off by 1.3%
When weighed plane, nose gear off by 1.1%
(these two tend to cancel, so if it was the scale that was off it would need to be off by 9%)
When weighed plane, main gear arm off by 0.2", OR nose arm off by 0.6"
Pilot weight off by 40 lbs
pilot position off from average by 1.4"
bag weight off by 3.5 lbs
bag location off by 10"
fuel off by a bit more than 60 gal
