FlyingArcher
Certainly a dumb dumb question because nobody asked it before, but I can't clearly read the plan (DWG-9) to determine how long this plate is supposed to be. Does it reach the main spar and butt against the top and bottom skins on each side, or should it be cut just before the spar so as to not interfere with the skins and add thickness?
Thank you
Thank you
