VS705 and VS706 are missing the after holes
dbaflyer
I assembled my VS tonight readying it for match drilling. However the two nose ribs only have one hole drilled in little tab portion. Whereas the skin has two. The hole most aft in the little tab portion is missing. Is there something I'm missing or should I just match drill the missing one using the hole in the skin as a guide?
Hi Denis,
There are a lot of times where the ribs will not have pre-drilled holes in some spots throughout the project. Just draw a line down the middle of the flange with a fine point sharpy so you can locate the center of the flange under the skin predrilled hole. then final drill the new hole in the flange of the rib, using the skin as a guide.
