When drilling the VS-410 hinge brackets to the rear spar and doubler, the holes came out slightly oblong despite having everything clamped tightly and the drill held parallel. Some of the oblong holes are around, 0.139 diameter in one direction which is slightly above mil-spec. A #29 drill bit (0.136) will not fit thought the hole though, but these will get larger after dimpling. Am I still able to use this spar in the current condition?
https://photos.app.goo.gl/CSLo4oJVFao19AWE6
