[email protected]
I just finished the directions for mounting the HS and VS on the tailcone. AFTER I finished match drilling everything and mounting, I put my crosshair laser level to it. if the HS is perfectly horizontal, then the laser lines up with the bottom hinge the laser is about 3/8ths of an inch to the right of center on the top hinge. Unfortunately I did not check this until AFTER I match drilled them all. Do I need to do anything about this? The directions does not have anything about aligning them to exact 90 deg.
Tried searching for this, but the search said it would not search for VS or HS as it is too short.
